baja minibike engine dies when under load
gvfc2
wishing i was living
Tacoma,wa
Now just to make sure when removing the govenor i dont have to upgrade anyother part unless i upgrade the valve springs right? Because the valves start to flutter at a certain rpm which would act like a rev limiter correct? For the exhaust i was wondering where i could just by a premade one. Dont feel like making my own. For the muffler a briggs and stratton straight type would work and make it quiter?
gvfc2
Tacoma,wa
Ok. Just wanted to make sure. So it is safe to remove governor with out upgraded other parts. I will remove if i feel the speed isnt enough.
Im using a 12 tooth clutch with a 72 rear would this provide decent enough torque on dirt road? This would equal a 6to1 ratio
gvfc2
Tacoma,wa
One thing i gotta say about the throttke on the predator is it sticks right out of the box so you gotta add a stronger spring to the throttle lever. I took the ground to the knee. Lost control and barely missed a parked car. Used my knee to turn the bike. Rear wheel barely missed.
Adding a 9lb spring to the throttle arm hopefully it works better
And about me worrying if tye ratio would have enough torque it has more than enough and probably has a high top speed too
gvfc2
Tacoma,wa
well i just checked the rear sprocket again and it only has 70 teeth not much of a difference
Just my 2c worth.....but if it were me, I would rather get a smaller clutch sprocket or larger axle sprocket. I hate the idea of messing with the governor. So many things can get affected when you open up an engine
gvfc2
Tacoma,wa
true. but thats not going to happen for another year. dont want to do any mods i cant undo. got a 1 year protection plan
Jcotz
...wasn't there
NY
If you don't want the throttle to stick, then loosen the bolt tightening down the lever. I had to do this on mine.
gvfc2
Tacoma,wa
hopefully getting my twist grip today. but my dad wont let me ride unless i get a helmet. a full head helmet. can you guys recommend a good but cheap helmet?
gvfc2
Tacoma,wa
That looks awesome better than the one I got. My dads friend I'd letting me buy his helmet
gvfc2
Tacoma,wa
well took it out today and got it gps verified it goes 26 top without the throttle fully open. twist grip wont allow me to have it fully open
gvfc2
Tacoma,wa
so i took it off roading. feels nice. need to replace the rear tire now as im sure from all those little rocks some punctured it. feels fast too. gotta clean it up now seeing as i was in a place with real loose dirt so it was making alot of dust.
