Baja heat mini bike
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
yeah id get that kart. looks like he doesnt take care of his stuff though, notice the dirtbike just laying there in the background. but yeah if the drive line is complete and alll that needs fixing is the motor then definitely get it. prob just tpical stuff, new sparkplug, oil change, clean the carb, some fresh gas and youll be up and riding. then strip it down paint it up nice and your good :)
kendelrk
redneck engineer
westland michigan
20 bucks and alot of fun until i get the stuff for my baja, and even if he dosent take care of it, i sure will, id probablly strip it, wash it down, hit it with a wire wheel, nice coat of paint, engine running, put it back together and have some fun, maybe the steering will work on this one, lol
kendelrk
redneck engineer
westland michigan
okay guys, the dude above was an a-hole, never called, whatever, so i called some guy in westland named matt, and he asked for pics and said if him or his buddy was intersted hed trade me a genuine comet 30 for my baja, im extremley happy right now
B.M.800
TheBeal.
Central PA
Wait what? the guy wants to trade for your bike?
You jus got the thing....
:confused:
Personally, I wouldnt...
kendelrk
redneck engineer
westland michigan
i must have worded that really messed up, the guy said if him or his friend wanted the manco mini bike, he would trade me a genuine comet 30 for my baja, so basically its trade the manco for the torque converter
kendelrk
redneck engineer
westland michigan
im probablly going to trade him, and then hell, finally take care of these brakes, i mean i can feel the clutch slip, and my brakes arent ever right so they drag a little bit and the governors like **** this, engage
kendelrk
redneck engineer
westland michigan
the governors acting up because the brakes are sticking on, im also getting new brake pads, so with new brake pads with no squeak and no drag, then the TC will give me some more speed and acceleration and ill never be off that thing, ill be tearing up mine and the neighbors yard and having some fun,
kendelrk
redneck engineer
westland michigan
alright so IM BACK, ive been playing with the baja thesse lasts 2 days, and i must say im upset, my brakes stick on only so much and it produces so much drag on the tire that its alot slower than usual, the motors running well, but the bike seems shaky on take off,probablly because of the drag on the tire,still havent got my torque converter or brakes, would one of the torque converters from mfg supply need grinding? i still need brakes to, im thinking about paying 40 bucks for the new hub and all
B.M.800
TheBeal.
Central PA
Can you loosen up that arm? If that dosnt work, take the nut off...
If theres still drag, something else is messed up.
kendelrk
redneck engineer
westland michigan
okay started playing with this today, pulled the brake lever off, so no brakes for me, still a loss, found out A of my problems, my chain was to tight, my clutch is still worn to hell, but freeing up the tight chain made a great difference, as of right now, i need my brakes, for sure, i need my TC, for sure, and as of right now, take off it reasonablly shaky, ive checked the motor and its bolted down tight, but take off is really shaky until the governor kicks in, is it always like that? or is somthing else wrong?
B.M.800
TheBeal.
Central PA
When I first gun it it make quite the vibration through the bike, then evens out once it get going. Also does that when I let up on the throttle topped out.
Go over all the bolts and everything, make sure it tight. Found out all but 1 crankcase bolts was loose. Problem is, I dont know how tight they should be, dont want to strip out the block... Later Ill take them out and locktight them.
kendelrk
redneck engineer
westland michigan
i say get a torque wrench first and get them torqued to spec, then take a marker and mark the bolt, so when you tighten it in, youll know how tight it is and when the mark lines up. ive checked all my bolts and everythings good, but when i hit the gas from dead stop the motor seems to kick backwards till i get going, then it evens out, if i let up on the throttle and hit it again, its all smooth, its when starting from low, or no speed. i definetley didnt miss those brakes squeaking, but i miss my brakes lol, so basically i need TC brakes and brake cleaner, like when i hit the throttle it kicks back just a little and vibrates the whole thing, but as long as its normal im cool with it, i know my clutch is worn to hell tho, you can hear the clutch squeak and all, and yeah, replacement with a TC soon
