chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
NO NO NO Wait!!! Take him up on that!
I want to see
"Indians Fan" under Bobs Avatar.
I want to see
Right here Bobby! But it wasn't rusted like the pics.So where did you find the 60T? Was it custom made, or did you have to drill the sprocket?
I've been reading that the Coleman and Baja's have the same odd sprocket bolt pattern and hub bore????? My nephew took his Baja to his house for the winter.
Well that doesn't seem too odd. What the fund were these knuckleheads talking about. Hmmmm?????? BMI has similar sprocket but says 2 13/16 instead of 2 3/4.
Also BMI painted the rust in different locations.
http://www.bmikarts.com/-Out-of-Stock--Sprocket-4140-60T-Dual-Bolt-Circle_p_4201.html
I had zero problems putting it on my bike.Well from the comments of your link....
I searched all over for a 60 tooth sprocket to fit on the rear drive wheel of my Coleman CT200u minibike. I wanted to gear it down slower and with more torque. I could not find a 60 tooth sprocket that fit the hub on this minibike. I took a chance on this sprocket. The hub was bigger than the OEM 52 tooth sprocket and the bolt holes didn't line up. The hub on this sprocket was bigger so it would fit around the smaller hub on the wheel and this wasn't too big of a problem. The bolt holes had to be modified so I just drilled new ones in the new sprocket. That worked. This sprocket is a little slimmer than the OEM one and the teeth are more pointed but seems to be strong enough and is working with the 420 chain I had. I've only driven it around for ten minutes since installing it but it seems to work fine. Maybe it should have five stars. I gave it four simply because it wasn't quite right for me and I had to modify it but I kind of figured that would happen going into this purchase. The price was the lowest I could find for a 60 tooth sprocket, even though I had to pay an additional $11 or so for shipping. Delivery was only a few days. Overall, this purchase from this seller was a satisfying transaction.
---------- Post added at 07:23 PM ---------- Previous post was at 07:19 PM ----------
Maybe the SuckMart Minibike is different than the Baja???
Joe..?
