its a late 60's or early 70s. It would be fine on a kart. Only thing is those have annoying updraft carburetors. The butterfly on the carb is VERY playful and genneraly it is going to be little throttle or WOT. They are pretty inexpensive, i payed 60 for a rebuild kit and payed 30 for a valve job. Plus 15 for a hone tool. And 30 for a carb kit So your looking at $145 to do this. B4 you order anything, do a compression check, pull the head and check the valves and cylinder. Good Luck!
