Axle making
ubersoldat
Lithuania(EU)
Hi, I have a question. Do you guys buy a rear axle or do them yourselves? And if there wouldn't be too much trouble could you drop a few photos of your own axles?
ryf
right about the steel, but most of the ones you buy are tempered to have springy flex and not bend extreme/permanent under normal use. tempering and type of metal makes a big difference. you don't want mild steel axles unless you are a lightweight, as these will likely fail quickly under offroad use
2or3wheels
Minneapolis Minnesota
nicely put
