Awesome lowbudget gokart built from scratch!
r_chez_08
Should be in the shop...
Cornwall, UK
only thing is that starters are not designed to run for any period of time. but good idea, give it a try!
awesome kart!
Redneck
Gothenburg, Sweden
I just figured i don´t want to step out of the gokart and push it... PAIN, better do it right, and with class! I think this is a relativly simple yet reliable system... and yes it´s only made for going backwards short period of time ! but that´s enough time !
Thanks for the awesome feedback dudes!
Very interesting reverse concept, it has the potential to work quite well. Obviously, it's not something you're going to use constantly, so it should be OK. Nice work!
nerfo
Madison, WI
I think you'll be ok on this. Backing a go kart up will be WAY LESS load on a starter than trying to crank an engine. As a rule of thumb, they say you shouldn't crank an engine over for more than 30 seconds at a time with two minutes in between to allow for the starter motor to cool down. You ever crank an engine for 30 seconds straight? It's an eternity!!! That'll work GREAT for backing up a go kart!
Redneck
Gothenburg, Sweden
thanks for this information nerfo.
I have´nt done any maths considering the reverse (wheel/flywheel diameter) only thing i know is ... that it will go backwards when cranking the starter! and there will not be so much load on the starter.
Whats left to do before testrun:
front tires/suspension
gastank
battery holder
and some electrical wiring
Redneck
Gothenburg, Sweden
i found an idéal tank from a dirtbike laying around, so i welded some mounts for it, and now it´s in place! thats one thing to cross-of my "to do" list :thumbsup:
the front tires/suspension are the major things left to do before the big testrun!
i have done some maths, and i figured the kart will probaly go 70+ km/h=onough speed to be killed :D
nerfo
Madison, WI
I love how GPS units have made is possible to validate top speeds of go karts so people can't carry on about how their go kart can hit 60 (96 kph) because their "buddy" followed him in his beater truck once. Of course, we can still lie on this forum... but I think theres a lot to be said about integrity. I can't wait to use mine to test the top speed of my kart when I finally have it all done and the weather's... well, go kart test drive worthy. 70 kph (or 43mph) sounds reasonably fast... especially when you have a transmission to help get the thing going! You'll have to let us know how she turns out after you've got your front suspension and tires done!
Redneck
Gothenburg, Sweden
Soo....At this stage i´m not far from done with the front end of the kart, and it has been a pain in the a** with all the precision work! but its soon coming to an end!... LUCKILY!...
i´m preparing the kart for the testrun, checking ignition/clutch etc. all the small details will be finished after the testrun!
The deadline = before the snow melts :thumbsup:
crazycart
RedNek Engineering
MINNESOTA
Where your wheels attach front and back look kinda iffy.
On the rear it looks like your axle will snap right where it comes out of your pillow block bearing. On the front that spindle looks like its just going to bend that angle iron when you hit a bump....I would put more braces on that.
BUT! Your ingenuity is wonderful. How old are you? Is it just me or are Swedes like the pure spawn of creativeness? NICE WORK!
BriggsTwins
Pittsburgh pa-Tallahassee- fl
good poiint, the backs i wouldnt so much worry about, the suspension should take the brunt of the ride, the front however might tweak a bit. most you can do to strengthen it is weld a piece of flat into the back and the front. but on the lighter side it may take the beating fine, only time will tell
Redneck
Gothenburg, Sweden
Thanks dudes! well I´m 17 , for answering your question!
I will se how everything goes and if the welds are holding during the test run. then I know what i will reinforce/fix.
I don´t follow any plans or such, couse I have a picture in my head. Cretiveness is the only thing Necessary! and some Measurements to get it straight of course :D
ironman
I'm Back!
kentucky
Thats has to be one of the best well built go karts i have seen on here in years!!!!
but i think you need to change the titlein the tread... how much do you have in it now?
Redneck
Gothenburg, Sweden
Thank you very much!
But one thing!: "how much what do i have in what now?
if ya mean timewise: i´d say i´ll testdrive it in one or two weeks
hopefully:thumbsup:
