I know nothing about older form of ignition (points, etc) and was wondering where the sparkplug boot is or wear it connects to. There's a whole bunch of wiring disconnected and there isn't a sparkplug boot. Any help?
There's also a ball of wires coming from the light on the atc into the frame and I see open connectors at the back.. Also connectors that used to be going into engine wires. Pulled the engine gonna rebuild it.
Not on a honda motor more like a black box with 2 blade terminals+plug wire. A motor like this probably used a CDI system, you need the vdi and coil, im pretty sure the stator and pickup is already there.
EDIT: those parts are probably still on machine, hard to tech something 300 miles away.
