I am running a modified gx 160 pushing about 8 to 9 hp. i currently have a higher grade comet clutch and i run either 60 tooth or a 100 tooth gear on the axle. I love the torque from the 100 tooth but it maxes out at about 50 km/h. Plus i wanna be able to get that low, kick in the pants torque needed for off roading. Using the 60 tooth gear i get torque in the mid range and can hit about 70 km/h. Will the tav2 give me the torque i need or is it not worth the money? keep in mind im on a tight budget and this would be the last upgrade.
