bajagokart
calgary alberta canada![]()
more albertans whooo hooo!!!!!
Still undecided on the motor. If I go for a dirt bike motor, I know how to make the shift linkage work, and I think I have enough room at the front end to run a foot clutch. I still would need to figure out some sort of starter. I haven't had any luck with that so far, although I have to believe it can be done.
The industrial motor / torque converter looks like a simpler option, but I know I'd like the power of a dirt bike motor, plus I would like to have the gearbox. We'll see. I'm still on the fence.
For a kick start setup, you could always fab a shaft with female splines on one end and male splines on the other.
Run this shaft from the kick start shaft on the engine, to the outside of the kart, add some bearings for support near the end and toss the kick lever on the male end of the shaft.
Got parts today. Waiting on bushings to come in for A-arms, and I'll start assembly on the front suspension, hopefully this weekend.
That's an excellent idea. Does anyone make splined shafts like that? I know shafts are sized by diameter and number of splines. Are they manufacturer specific, or is there a standard? In other words, if I had a Honda engine, would I have to go to Honda for a shaft to fit the kick start shaft, or could I source it elsewhere?
