Anyone have a genuine Comet 40 series driver they want to sell?
So Ive bought in total, 4 generic 40 drivers. The sheve gets cocked crooked, causing severe vibration but whats worse is it wont retract. I have to carry a small hammer to tap it and make it go back to rest. They all do this same thing after about a half hour of hard use.. Disassemble, clean and you have another good half hour of proper actuation.
Im 99% sure its the ramps and filing anything actually causes this issue to be worse as it allows the weights to rotate slightly inside the ramp. The weights have just enough room to shift and jam crooked on attempted retraction.
Now, I dont just try the driver and move on. They all get the same treatment: Filing/sanding, swap weights, springs, different lubes, parts between the 4...
Im doing some researchin, trying to find a fitting driver that has an actuation wherein everything moves in unison.
Is anyone else super hard on these generic drivers but DONT have a problem? They just work?
Yea, I had an extra spacer on the driven, thats why it looked off to me.
So I got a chance to try a Comet driver and its working just fine.
I wonder if the cheap drivers have just enough slop for my backwards mounting to have an ill-effect.. I bet thats it.
I had a very similar problem with mine.
look closer at the damage pointed out in the pic.
the two halves are slipping causing the two pieces to get misaligned then the weight jumps the ramp and jam up. The symptoms you describe fit exactly.
its either a design problem, or the nut is not tightened enough, or as in my case it is operating beyond its maximum power rating.
l’m sending almost twice the rated power through it. After screwing with itseveral times l just gave up and welded it. Its been that way for many hours of thrashing and still works perfectly. I drilled a few holes so l could spray dry lube in it
Yea thanks. Ive actually been thinking of that exact thread youre talking about.
Welp, I have enough pieces that I can sacrafice some stuff to weld one up.
Just throwing it out there if anyone has one...
Looking for a billet rod also.
Im noticing people dont sell this stuff used. Why is that? Stuff just stays with the vehicle when its sold I guess?
Do you know the name of that relevant thread? I don’t own a 40 series but I like to expand my brain…
No but I can find it, Im sure.
Reviving old Comet 40 series driver, or something along those lines I think.
The idea was that it was so far gone that if the welding fix didnt work, it was garbage.
Mine does not jump the ramps, Im positive of that. I can always whack it with a hammer and it pops back into place.
Still gonna try the same fix though.
