anyone got a shredder kart?
Routy
was wondering if anyone had a shredder kart from ubuilditplans.com, i want to build one but would like to here any complaints or awesomes about it. here are pics of what im talkin about.
killawatt
tried to get banned
the engineering club at south alabama built something very similar to this it was a kit competition where several universitys get a kit and can only use the things it and then we race them... i loved the design because it was very simple and basic also light and sturdy ours was a live axle and that was definantly awsome had a single disk brake on the rear axle and was very fun the only major problems we had with it was the motor came out past the frame and we bumped the motor on one turn that almost knocked it completely off the frame so consider that also idk about your but ours had no suspension which sucked when going down the rougher part of the course also all the weight was in the back which was great for traction but we thought it would roll over up hill and added what was basically a wheelie bar but that is the case for most carts hope that this helped man its a cool cart and a great design
alex
redsox985
PA
That would be a good kart to build but taking it off jumps and getting that much air can't result in comfortable landings whenever there is no suspension.
r97
Measure twice cut once
Massachusetts, USA
just look at there website, the site itself might not be too fancy, but from what i can tell the plans are prob superb! i'm tempted to build the 2 seater, watch some of the vids.
p.s. does spider carts have any vids of the arachnid going off jumps, not to mention a kart with no suspension, being fine with it? i would buy them, even if they are crap, its only 20 bucks. i like how your willing to buy plans.
redsox985
PA
From what they say, their plans are very through and detailed. They at least sound good.
killawatt
tried to get banned
it definantly needs one if your wanting to jump it or its going to hurt youll at least want a double a arm front suspension which wouldnt be that hard to modify into the original plans and would at least offer you some kind of cushion upon impact... it all really depends on what you want out of it and what you want your cart to do
r97
Massachusetts, USA
first time i have seen ackerman mentioned on a website for plans. i still like the 2 seat one :D
Routy
ya i like the design, building carts at a university and racing them would be awesome! My mane concern with this is the suspension but i dont plan on any major jumps mostly climbing, muddin, and back roads. another prob i see is steering, it looks like the wheels could hit the frame when turned to hard.
killawatt
tried to get banned
well if you go with a double a arm suspension your ride will be smoother and you can extend them out so on sharp turns you dont hit the frame otherwise what we did was simply put a stop bolt on each side that hit the front wheel hubs and kept the wheel from ever touching the frame... and yea man it was definantly a lot of fun competing our cart against other universitys it was crazy seeing all the different types and set ups that schools brought and it was a good turn out over 30 university's competed
Routy
nice how was the track? an did you guys have suspension on your kart? i think no suspension can be funner inless your doing big jumps than you need it.
killawatt
tried to get banned
it was a really cool track actually and you raced 6 times (because theres 6 people to a team and they wanted everyone to drive) and each track was diffrent. there was a lose gravel oval. a sort of mud quarter mile thing where the mud got deeper and depper. a rock crawling type track. one where its just trails and you basically just negitiate a lot of turns. one that was like parts of it you where on really dry dirt then on a road. then for the last one it was a hill that got really steep at the top and it wasnt even really a race it was just who made it furthest up. we had a very interesting set up for the suspension though deppending on what we where doing we could have one or not basically we could put one on or just bolt the a arms right to the frame we ran it mostly without one though
Routy
thats cool that sounds like a blast. so what race did you do. and how long did it take to bolt on the suspension
redsox985
PA
It could be a quick change if you had them bolt on with large enough bolts that you could drill a hole in and use a hitch or cotter pin to drop through and secure them.
r97
Massachusetts, USA
you could just use a simple rear swing arm(or a simple irs using a js lined up with the suspension pivots, i'm not sure if that design has bean tested yet, but i don't see any huge problems, would bring up a thread about this idea but i recall it was mostly people arguing), and some single a-arm front suspension, would definitely change the look, and you would have to alter the cage.
killawatt
tried to get banned
yea your on the right track except we didnt use bolts it was some fabricated solid rods with two smaller rods welded on the end basically made a big T but welded on each side of the top of the T were two bolts that ran parrallel with the large solid rod then the top mount of the shock and mounting bracket for the shock were both sort of keyed for the T then you push and twist and the two bolts locked in two holes on the frame and a spring kept the whole thing from just falling out. when your ready to take them off you simply push and twist and do the same at the bottam and there off
killawatt
tried to get banned
here are some pictures i happen to find sorry about the quality i had to take pictures of pictures this is about a third of the teams that showed up i cant find the others for some reason
killawatt
tried to get banned
here are just some action shots that is our cart i think climbing the hill i cant really tell im hopeing i can find the one of us crossing the mud its crazy
killawatt
tried to get banned
ok i cant find the one in the mud pit but heres an aftermath picture hope it gives you an idea
the last picture is the picture of the cart that won it was really amazing
