anybody try the 99 cc Predator engine yet?
robbie
Osceola, Missouri
Has anybody out there tried the new Predator 99 cc from Harbor Freight yet? I had a couple of their 79 cc engines (2.5 hp) and I loved them. I had those set up with approximately a 10 to 1 ratio using a jack shaft, and they had plenty of power.
I'm thinking of using the 99 cc on a mini bike with 11 inch tires and a ratio of 6.54 to 1. I could make this happen with an 11 tooth clutch and 72 tooth sprocket and #35 chain, although I'd like to see a smaller sprocket on the back. I could go for a 60T on the back for better clearance, but that would give me only a 5.45 to 1 ratio.
With 25% more displacement than the old HF 2.5 engine, this engine should handle a 6.54 ratio, I think. But I wouldn't expect it to handle anything less than that.
I dislike jack shafts enough that I would probably go for the bigger sprocket and put up with bad sprocket clearance. Any thoughts?
Blazkowiez
Kart Aficionado
Houston, Texas
Put one on a doodlebug already, the power difference was not noticeable versus the stock engine. Thought very very little of this engine, not super easy to hook up and no improvement.
robbie
Osceola, Missouri
That's good to know. Did you put it in the doodlebug with stock air cleaner and exhaust? The stock exhaust on the HF 2.5 is really restrictive.
What do you think of setting one up with a 6.54 to 1 ratio and 11 inch tires?
Blazkowiez
Kart Aficionado
Houston, Texas
We just mounted it for a customer so nothing was done to modify it period.
As far as that ratio, can you please show me what you're attempting to build?
robbie
Osceola, Missouri
The first post pretty much explains the whole thing. 11 inch tires, mini bike, 6.54 ratio. I'm limited by available parts, and my only dilemma is the sprocket clearance in the back. I could do better with the clearance if I install a jack shaft, but who would want a jack shaft if it can be done without one?
robbie
Osceola, Missouri
What about those classic mini bikes with the 3-horse Briggs engines? What kind of ratios did they use? I'm pretty sure I've seen lots of photos of old bikes without a jack shaft.
I have 2 boys who are 12 and 13 years old, so just about anything I build will carry them around. But I weigh almost 250 pounds, and I'd like to ride it, too.
For those of you who say "get a motorcycle engine" or "get an airplane engine", I have 2 sets of ATV tires to build mini bikes out of. The tires are around 22 inches in diameter, and I have a HF 6.5 engine. I just need to get in touch with my friend who works at a machine shop so he can build me some rear hubs to hold the wheel, brake and sprocket. Until then, I thought it would be fun to put a dinky bike together out of stock parts with a small engine.
robbie
Osceola, Missouri
Thanks for the link to the speed calculator, although for fairly obvious reasons I like this one: http://www.diygokarts.com/vb/showthread.php?t=9591
With the bigger sprocket and 6.54 to 1 ratio, the proposed bike would go about 20 mph at 4000 RPM. That sounds like it's in the right range.
So........ I suppose nobody has used the 99 cc engine yet. I think I'll just go with my gut feeling and build the bike as planned, then I'll be the expert and tell you guys how it turns out.
slideways
The stock Doodlebug motor is a 97cc... and its absolutely terrible. Not sure how much you are going to gain with a 99cc. Are the new predators OHV?... if i recall correctly i think the DB30 has a 72t gear to a 12t driver... 6:1 and it is awful. It accelerates fine once you get it up to 15-20mph but it has no power otherwise.
They make jackshaft kits for them that cost about as much as a regular clone to make them driveable. Or you could just swap the clone on and be in great shape. Both of my Doodlebugs have stock clones and they are a bunch of fun... especially now with the hydraulic brakes.
robbie
Osceola, Missouri
Thanks, this is good information. I looked up the specs on a stock doodlebug, and it has 14.5 inch tires. If I go with 11 or 12 inches, and the 11 tooth clutch, I have a hunch that the performance will be acceptable.
