Any idea what brand bike?
SpiderSpartan
Cincinnati, Ohio
I picked this thing up yesterday. It definitely needs some work, but couldn't pass it up for the price. The only markings I've found on it so far are "gs moon" on what looks like the starter motor. Any idea what I got here?
Its chinese.... thats for sure.... that motor look like it is backwards and also the sprocket was welded onto the shaft......
Most likely be better to put on a clone and forget that thing....
Frame so far looks alright...
it's a TY-S601
at least that's the only twin rear wheel "mini harley" I was able to dig up
Dimensions:135(L)x 97(H) cm
Engine: Single Cylinder Air-cooled 2 stroke Piston
Displacement: 43cc/49CC
Max Speed: 28km
Starter Way: Electric start-up Pull start-up
Ignition Method: CDI
Load Capacity: 100kgs
Fuel type: Unleaded gasoline: 2 stroke engine oil=20:1
Fuel Tank Volume: 1L
Distance on Full Tank: 35-45km
Tire Type: F.13 inch,R.10 inch
made by Tianyun Tools, Zhejiang China.
SpiderSpartan
Cincinnati, Ohio
It does seem to be an odd setup, even to someone not really familiar with these things. I have a 5hp Briggs that came off my recently modified thunder kart, but it's missing an engine shroud. I can start it with a drill and it runs fine otherwise. I've been trying to find a shroud at a decent price for the last few days.
He aint going to find a briggs motor shroud there... thats all those china parts for everything else on the bike....
ML-TOYS
long island, new york
Its a pain in the @$$ !
Gotta get a engine mount in the right spot, fit a jackshaft on it, unless using a tensioner you need to make the rear rigid.
Notice i turned the rear wheel around and added a disk brake. You need to mod to fit a sprocket with the correct tooth size since it has a #25 chain on it now or a bicycle size.
They are cheaply made mini choppers by MRC i believe.
ironbutt
Pacific Northwest
Looking at the model and it's available accessories online, it looks like junk. I'd save the seat, frame and front forks and build from there.
The front forks look cool! They sell for $40 online, but the neck stem tube diameter is non-standard I think. You can use it on another model mini.
And Zhang Wei beats each and every one leaving the factory with an ugly stick. Word on the street is that it's an automated Ugly Club® now but he still has to push a button. He has good job security too.
Even though I'm a purist fan of the small-wheel minibike, that thing NEEDS bigger wheels...:ack2:
ultralight01
Senior Yet Young Member
Hood River, OR, In a galaxy far far away
it's a TY-S601
Max Speed: 28km
Whaaaaat?!?!? This thing is factory made like that!!?? :surrender::ack2::smiley_omg::huh:
Poboy kartman
Senior Moments Member
White Settlement Texas
Anyone know a good source for shrouds in southwest Ohio?
You could also check nearby metal recyclers...each one is different on how they operate. I don't see why a horizontal shaft engine shroud wouldn't work.
Might have to buy a whole lawnmower for $30..take it back and get $5...
Check a lawnmower shop for compatibility...and maybe they have a used one?
don't look at me.. I cannot be held responsible for all the abominations that emerge from chinese factories :surrender:
But yes.. I'm afraid it's as ugly as it leaves (has left??) the factory.
(I hope it's discontinued by now)
hodala
Taiwan
How do those rear twin wheels work when cornering? looks like bolt togather in a bolt
