Another steering problem... šŸ‘½
Where the steering rack is supposed to pivot upward, needs to be align with the pivot of the a-arms. That will prevent bumpsteer (what you have).
anickode
S.E. Michigan
I don't know if you are going to find one that is short enough to fit in the center of the frame without protruding beyond the inner pivot point of the a arms.
Steering and suspension geometry can get really tricky, particularly when you're looking at a relatively long travel relative to the width of the suspension.
If you cannot find a shorter rack, your next best option will be to widen the frame where the a-arms are supported, out to where the rack will pivot upward inline with the a-arms.
Kentguy13
Akron, OH
Thank you all for pointing me in the right direction. I researched ā€œbump steerā€ more last night and see what youā€™re referring to. I found a rack that is close, about an inch longer than ideal. I may try that first before having to fabricate a new front end.
Kentguy13
Akron, OH
So I extended the frame and bought a shorter steering rack. I have minimized the bump steer, but not eliminated it. Iā€™m thinking what is remaining is due to the difference in angle between the A arms and the tie rods? If I elevate the steering rack so the tie rods are parallel to the A arms, will that help?
Any thoughts on the wheel travel? I originally thought one had a sharper radius than the other, but it may just be an illusion.
Kentguy13
Akron, OH
At it again.
Well I cut the entire front end off today and started fabrication on a new one. Hopefully with a better understanding of bump steer and Ackermann.
Bansil
Painter of gnomes....
I am a big fan for offroad of equal length and equal spacing (vertical ) a-arms that way you have no camber changes, for bump steer the tie rods need to be same length and same pivot points...no of course on road w/o the slippage...this would be crappy...BUT you could do some serious 3 wheel action with enough power :wai:
Kentguy13
Akron, OH
574B776E-6CA0-4D35-AF50-385E63D22388.jpg 0A86F3A6-ACA0-40F7-8E58-DD14BFA5C87A.jpg
Iā€™ve been really slow on this project šŸ˜¢. Here is some work I did yesterday.
The A-arms are the same length, but the calipers have an offset built into them, so I made the top frame rail larger in order to keep the A arms the same.
Kentguy13
Akron, OH
Hey mate. I'm having the same problem as you. Have this helped you at all?
The above fix seemed to help quiet a bit. Itā€™s not perfect, but I think thatā€™s on my end, not the mechanics of it. What part are you having trouble with?
