c nichols
i'm the guy with the 440cc snowmobile engine needing some info but i also have a clean running briggs 18hp motor with a horizontal output but the shaft is tapered.... will it still work??
i'm the guy with the 440cc snowmobile engine needing some info but i also have a clean running briggs 18hp motor with a horizontal output but the shaft is tapered.... will it still work??You guys giv up too easily aye! You can use it for sure just come up with somethinng to hold er on!
