The pulley on the engine, or the driver has weights in it, so when the engine spins it the weights are pulled by centrifugal force and cause the pulleys sides (sheaves) to move towards each other. When this happens it tensions the belt and begins to pull the belt down into the driven.
The pulley on the jack shaft, or driven pulley, is spring loaded, so at idle it pulls the belt to the top of the pulley, but when the driven closes and pulls the belt, the springs allow the driven to open so the belt can go down further into the driven. The driven also has a cam on it, so if a load is applied to the torque converter ( the load could be, for example, climbing a hill) it makes the pulley close and pull the belt out of the driver.
When these two pulleys work to gather it causes the ratio to increase for high speed when there is less load on the engine, but allows the system to essentially shift down when more power is needed, and it does all this seamlessly, and automatically.
P.s. Slang for torque converter is "tc".
EDIT: darn! Toy story beat me, and I spent 9min typing that on an I pad! Oh well, the OP will really understand now! Lol
