Richard III
- Messages
- 21
- Reaction score
- 4
ok I have a tecushem h70 engine that came off of a snowblower engine. It runns pretty well when it idels (idels a little fast but all i have to do for that is turn the idle screw a bit and that should be fine) and it runs good when I press the gas, the only problem is when I put the air filter on and then the engine wants to die or dosent start at all and when i press the gas with the air fillter on the engine starts to run godd and then dies completly. I did a search on here for this problem and dint get to far so if any of you could tell me what to do and I tried to turn the screw at the bottom of the carb and that didnt help much (but i think it has to do with one of the set screws in the carb)
ill add pics if i can later
Thanks Ricky
I am goign to go take the carb aprat and see if that help but i still think it might be one of the screws so if anyone could help me thad be great.
Thanks Ricky
