aftermarket exhaust
ironman
I'm Back!
kentucky
what would you guys thinks would be a good aftermarket and how much extra power do you recieve out of it .For a 5hp b&s motor.
ironman
I'm Back!
kentucky
so russ do you think removing the muffler and puting on a straight pipe would help any
Russ2251
AZUSA:Powered by LAWN-BOY
The gain is so small in 4 cycles (another story on 2 cycles) it can barely be measured (much less felt). Loud exhaust gives the illusion of power. Some folks will disagree.
On the other end of the scale, high end performance engines require specially designed exhaust systems to take advantage of high lift and long duration cams as well as exhaust scavenging properties. A standard consumer type muffler on these engines would restrict output.
For the most part, the engines we use on our 'toys' are not kart specific, but are considered 'all purpose' engines.
It tickles me when I see some guys put on 3 pounds of pipe and elbows and believe they have increased power. In reality they increased overall weight of kart and lose any possible gain in horsepower.
If/when I use a straight pipe on a 4 cycle it's only because I like the noise and the illusion of power.
I use a straight pipe/megaphone on 2 cycles out of necessity.
Jerryburger
Admiral Annoy
The Nation's Catbox...er, AZ.
I have a sick old oil-burning B/S 5hp flathead, and looked up what the kart racers were running on their engines. Ended up putting a 14" straight pipe on it. Yes, it's louder and yes it does have a better top-end pull, but again, this was on a sick old Briggs.... A stock HarborFreight 6.5 will dust it. Build up a collection of parts and try what's best! I think a flathead briggs could also be improved by adapting a better carb set-up on it. (Not necessarily bigger). I've Assburgered old tecumseh diapham carbs onto Briggs 3hp engines, and they seem to run a lot better. Okay. I'll shut up now. Russ- can't wait to see how the snowblower engine works out for you!
ironman
I'm Back!
kentucky
today i added on a 14 inch pipe on my 5hp. and i gained 1 hp went from 23 to 24mph.i know its not much but every mph can make a different.:thumbsup:
ironman
I'm Back!
kentucky
here is a few pictures of the new muffler i bought for the 5 b&s
Jblankster
Illinois
mph, and horsepower have no impace on each other, i highly dont think it made 1 hp. hell i bet it diddnt make half of .5 hp. it was prolly like wind or something. like russ said, its the illusion of power.
kibble
I banned myself
I wonder if he meant to say that he gained 1mph, not 1hp.
ironman
I'm Back!
kentucky
yes correct that is what i meant to say . my bad for the miswording. yes it was 1 mph which still shows how an ad on like that can make a different in your speed.
kart_racer20
the longer the exhaust the more back pressure it will have but the exhaust alone won't give you any more hp the cam is what gives it the hp if you put a bigger cam in it, it will have more hp but you have to be careful or you will bust out your lifter carage
Russ2251
For a true test...put muffler back on and re-check mph. Do it several times and average it out. I'm sure you may have gained 1 mph ...but is it due to different exhaust? All my engines behave differently according to what brand of gas I use.
The bigger the engine...the more noticeable it is.
Weather also can affect hp. Ever notice how engines run better just before a thunder storm?
Are you running with governor?
Consider increasing compression ratio.
