Advanced Hemi 212cc Predator Build
When the town you work in throws a festival and you have not one customer.
Poboy kartman
Senior Moments Member
White Settlement Texas
They're all out buying pistol ammo, fieworks, charcoal, and beer....it's the 4th man....who needs a festival?
Get drunk...burn up some meat on the grill, pop a few caps skyward, blow off a finger or two.....it's what makes America great.
chancer
ɔ ɥ ɐ u ɔ ǝ ɹ
COMFORT, TEXAS
Dude he is in Chicago! They do not waste Ammo shooting it in the air, they shoot each other.
Final June Totals. Shot & Killed: 67. Shot & Wounded: 375. Total Shot: 442. Total Homicides: 71. 2016 Stats Shortlink. Week in Progress (6/26 – 7/2) Shot & Killed: 13. Shot & Wounded: 91. Total Shot: 104. Total Homicides: 14. Year to Date. Shot & Killed: 301. Shot & Wounded: 1687. Total Shot: 1988. Total Homicides: 334.
I guess that explains the locks on the door!
Flyinhillbilly
The great cornholio
North West Arkansas
The low speed jetting is the coloration of the bottom of the threads, the wot can only be checked if you do a wot pull and kill it immediately. It's read way down deep where the porcelain meets the threaded body, I usually cut the plug and slip that part off to get a good look at it. Timing is indicated by the place that your ground strap stops annealing, I shoot for the middle of the bend. There are some great charts online that will give you visual representations of what all of these things look like.
My last attempt at a plug reading. Was told it looked good.
Now I've got more info to use!
Flyinhillbilly
The great cornholio
North West Arkansas
You aren't going to have a chance at reading timing with a plug like that, all you can really tell by that one is that the low speed is fairly close although pretty rich as indicated as the black soot around the base of the threads. You'll have to make a wot pull and kill it with zero run time after the wot and either cut the threads off or get one of those lighted magnifying glasses to peer all the way to the bottom to know anything about the main jetting. You should research plug reading, I tune 900+ hp cars by the plugs, you'd be surprised what you can tell by them.
Let's not discuss my mother's battery usage. Lol
This is how I bleed my brakes.
So opening one bleeder screw on the dual MCP hydraulic brake caliper gets the air out of both lines???? Maybe broken???
No more visable air in the lines, but still feels loose. AND only the one side seems to work properly. It fully goes in and out and contacts the rotor. The other side only moves a bit. It stays near the rotor but never contacts it.
Hmmm???
Ill try to adjust the position of the rotor and the pads, but maybe need to buy a rebuild kit?
Master cylinder? Caliper? Both?
I messed with it before, trying to manually work the stuck piston. No luck I guess.
Maybe it is the master cylinder?
Who has time to wait for shipping on their day off.
Off to McMaster Carr to pick up the following......
2 x 24" Grade 8 24 tpi 3/8" Threaded Rod
2 x 3/8" 24 tpi male steel ball joint rod ends (3/8" ID ball joint)
2 x 3/8" 24 tpi female steel ball rod ends (3/8" ID ball joint)
2 x 3/8" 24 tpi female threaded clevis joint (3/8" ID)
Probably the coolest place out there!!!!!
All your DIY tie rod needs.
http://www.mcmaster.com/#rod-ends/=135ew5v
Flyinhillbilly
The great cornholio
North West Arkansas
This is what I was talking about on cutting the plugs, that black ring at the base is your WOT mixture. It's waaaaaaay easier to read if you cut the plugs.
Now that I have half a brake and will have a somewhat aligned front end, I can get back to jetting!
I decided the the 0.028" Low Jet was too big and now have a 0.026" Aftermarket Low Jet. This was the tight fit with only 1 O-Ring on the bottom (none on the top).
I have the 0.042" Main Jet installed now (which I expected to be a little big).
The engine seems to idle fine.
It seems to pull hard off the line.
It has good throttle response from a stop.
It seems like the engine doesn't want to rev up like it should. My tach wasn't working, but It seemed to give up.
I'm hoping a main jet adjustment is all I need??????
I think I will try 0.041" and 0.040" and see how it responds.
Also the alignment was jacked and I may have a TC issue as I noticed lots of play in the 30 series JackShaft and a slight wobble in the Driven Pulley
Plan B will be using gravity.
Plan C will be investigating the TC.
Plan D? Stock Carb?
And I do Appreciate You Being Round
HELP WITH JETTING AND FUEL DELIVERY
I know I should read the plug to get a reading of the air fuel mix, but I don't want to cut up a good plug if I am still way off.
Can anybody tell me anything based off of performance?????
The 0.042" Main Jet had me thinking about alternative plans B - ZZ Top.
The 0.041" Jet has me thinking about sand dunes!!!!!
I need to put a new pedal stop in to prevent me from pulling my wire hanger linkage too much.
The Low and Mid range is way better that it was. I'm sure it was faster (more RPMs than before) but still no gauges yet. I going off of feel for now. Butt Dynos are cheap.
It seemed to "sputter" and lose and power at WOT and high RPMs.
I'm not good with descriptive engine performance words like sputter, bog, hunt, surge, blah, blah, ....
Not always, but I had it wide open for maybe a 1/8 mile running perfect, flying - and then it happend???
I would let off the gas, then I would go back to WOT and it would rev up and then after some time, it would do the same. It makes me think the pump is NOT giving enough gas at High RPM?
Also taking the gas cap off seems to help fill the fuel lines when they are empty.
Could my gas tank vent be too small?
I can blow through it and have drilled a hole for a rubber grommet and tight fitting fuel return line. Maybe drill holes in gas cap?
Could it be the jetting is still off? It runs way better than it did with the 0.042"
I can try drill the stock one to 0.040"
Not Enough Fuel?
I can close the valve on the return line a little bit.
Too much fuel?
I can try gravity feeding the carb.
I am a little worried my linkage may have caused the butterfly to fluctuate?
I will fix the pedal stop.
I feel a reading from this plug will be tainted from the overly rich mixture from before.
The easiest for me to change is the valve on the return line. You can see from the Large Text, this is what I think it may be. I think I will close the valve half way and see what happens.
What do you think?
Still too many variables / not tuned enough to start putting new plugs in to only be cut up? OR????
