And I do Appreciate You Being Round
HELP WITH JETTING AND FUEL DELIVERY
I know I should read the plug to get a reading of the air fuel mix, but I don't want to cut up a good plug if I am still way off.
Can anybody tell me anything based off of performance?????
The 0.042" Main Jet had me thinking about alternative plans B - ZZ Top.
The 0.041" Jet has me thinking about sand dunes!!!!!
I need to put a new pedal stop in to prevent me from pulling my wire hanger linkage too much.
The Low and Mid range is way better that it was. I'm sure it was faster (more RPMs than before) but still no gauges yet. I going off of feel for now. Butt Dynos are cheap.
It seemed to "sputter" and lose and power at WOT and high RPMs.
I'm not good with descriptive engine performance words like sputter, bog, hunt, surge, blah, blah, ....
Not always, but I had it wide open for maybe a 1/8 mile running perfect, flying - and then it happend???
I would let off the gas, then I would go back to WOT and it would rev up and then after some time, it would do the same. It makes me think the pump is NOT giving enough gas at High RPM?
Also taking the gas cap off seems to help fill the fuel lines when they are empty.
Could my gas tank vent be too small?
I can blow through it and have drilled a hole for a rubber grommet and tight fitting fuel return line. Maybe drill holes in gas cap?
Could it be the jetting is still off? It runs way better than it did with the 0.042"
I can try drill the stock one to 0.040"
Not Enough Fuel?
I can close the valve on the return line a little bit.
Too much fuel?
I can try gravity feeding the carb.
I am a little worried my linkage may have caused the butterfly to fluctuate?
I will fix the pedal stop.
I feel a reading from this plug will be tainted from the overly rich mixture from before.
The easiest for me to change is the valve on the return line. You can see from the Large Text, this is what I think it may be. I think I will close the valve half way and see what happens.
What do you think?
Still too many variables / not tuned enough to start putting new plugs in to only be cut up? OR????
