Had to reverse engineer the throttle plate. LOL
I am using the cable guard retainer that is designed to be used when the throttle cable comes from the flywheel side (as opposed to the retainer that is designed to be used when the cable comes from the back of the kart).
The cable will come directly from the front of the kart and will be attached to the holder/screw (that holds the exposed wire end) that is designed to be used when the cable comes from the rear.
Using pliers and such I had to bend the lip on the side of throttle plate that is closest to the front of the kart to allow the cable to sit flush and straight in the retainer clamp.
A new return spring (in the opposite direction) works perfectly. Still working on the rest.
Pic soon
Pic soon
