This is one of those times when I take a wrong turn on purpose cause I was going to show up to the party too early and too sober.
I'll come back to the Cam choice after some more metaphorical pre-gaming! lol
Besides I need to pick a head first!
There are these options...
14cc
18cc
22cc
22cc Hemi
I know the 22cc Hemi has 27mm intake and 25mm exhaust.
I know the 14cc and 18cc has smaller (25mm intake?????, 24mm exhaust?????)
I'm not sure what the non-hemi 22cc has. If it is the gx200 head, I think it has the small valves too?????????
Milling the non-hemi heads helps un-shroud the valves to improve flow from what I've read.
What you you guys want to work with. I'm thinking similar compression ratio near 11:1.
---------- Post added at 02:04 PM ---------- Previous post was at 01:49 PM ----------
If duration stays the same, yes.
The relation of valve diameter to cylinder bore matter's greatly, compression ratio matter's, many factor's matter.
What does dynocam's recommend?
Quickly (meaning very polite, but ready to take an opportunity to say Good bye) he recommended the 275 which is 0.276" Lift, around 239/240 duration and said he can turn the lobes where ever I wanted.
We didn't get into that too much. The F-275 has 260 duration for 8000+ vs the regular 275 at 7000RPM.
With 1.3 Ratio rocker, I'll have a lift of 0.356.
I guess I also have to consider what is more important between compression and valve lift.
If max performance comes at 0.350" valve lift and max compression comes at 0.030" Piston to Head Clearance, it seems like there may be a trade off/compromise.
Then consider deck height and quench and now I'm glad I'm in no hurry to do this!
---------- Post added at 02:22 PM ---------- Previous post was at 02:04 PM ----------
Apparently the best head is the RTC-8 head off the 69730 Predator.
These are the droids I am looking for!
