SmallEngineCams.com
Custom Cam (gx200/clone/Hemi) $99
104 LSA = More Bottom End
108 LSA = Best All Around
110 LSA = More Top End
She is a waitress and a bartender in training. I ask her father and brother if I can marry her every time I see them. :lolgoku: I've offered goats in exchange.... I don't think that is how it works, but I've never been married so I don't know.:rolleyes:
Best part is she doesn't know that she is out of my league YET!!! AND she begs for a ride in the go kart!
That is how marriage works here by me, except that it is cows and not goats :D
I suggest you make your move before she finds out that she is out of your league
Flyinhillbilly
The great cornholio
North West Arkansas
Tighter LSA normally have a higher peak torque, but narrower torque curve. Have to consider valve overlap as well. Two cams can have the same LSA, but the one with more duration has more overlap.
^^^this, exactly this.^^^ it's a balancing act with cams between duration and LSA. If you have two cams with the same lift and duration, the one with the higher LSA will make torque earlier. It's all about what you want to do with it. Overlap causes some of the intake charge to go out the exhaust so as velocity increases the momentum of the gasses helps pull more fuel and air into the cc at higher rpm. That's why they're peaky with a lot of overlap.
I thought I responded last night, but must have fell asleep.
I was confused because I was thinking about each spec individually, instead of dynamically.
Of course increasing duration will increase overlap, unless you widen LSA , which will change the timing of the other cam events.
A true juggle indeed.
Thanks FHBilly and Cav.
Jrgunn5150
Rudderless
I thought I posted this last night.
Now you're getting it.
I see test often, where they claim to have only changed one facet of a camshaft, but that's simply not possible really.
As I seem to remember broader tq curve usuall translates to more HP in the upper RPMs (better for racing)
as compared to the higher max TQ, more narrow TQ curve, which may be better for street use with stop and go and corners??
Jrgunn5150
Rudderless
You have it flipped, a broader curve is better for street applications where you never really go WOT or see peak rpm, but use a variety of RPM's, below 3500 or so.
A peaky, higher up power band, is only useful in racing, where you simply pin the throttle and shift just past peak power.
Typically a broad TQ curve is met with a gently rising HP curve, not a "peaky" band.
It is much easier to respond to questions on here compared to Youtube. People are demanding on Youtube. lol
Like I'm probably not going to start taking stuff off and putting it back on just to make a video for someone who asks, "Can you make a video of [insert EVERYTHING here]?"
Also there is no help, just lil, old, ineperienced ME!
I send them all here, but I don't think they come.:huh:
Jrgunn5150
Rudderless
Funny I was literally talking about that on another forum right now lol.
Electronics just make it too easy for people to ask everything, even if it's been covered.
My head hurts after trying to put it all together... Maybe because of the Isky Family? LOL
Given a Constant Lift say .290 and Given a constant duration. Say 246 degrees...
a 104 LSA gives 38 degree overlap (online calculator)
a 110 LSA gives 26 degree overlap (online calculator)
AM I CORRECT IN MY UNDERSTANDING THAT THE LARGER THE OVERLAP, THE MORE PEAKY THE POWERBAND WILL BE AND BETTER SUITED FOR RACING?
THE SMALLER THE OVERLAP, THE BETTER FOR IDLE, LOW END, THROTTLE RESPONSE, AND TORQUE.
This is how I have been thinking about it for a while.
If that is correct... I don't see why the 104 LSA cams are advertised as bottom end and the 110 are advertised as top end.
The 104 will clearly have more overlap.
Jrgunn5150
Rudderless
No, you're backwards. More overlap=wider powerband. Most stock V8 cams are 114-110-ish. Initial response is softened with a wider LSA, which is why I run a 112 LSA in my race car, to keep the tires from rolling off it at the starting line.
You also need to consider EO/IO event's etc, as ground. It's a complex and dynamic system.
Jrgunn5150
Rudderless
Truth is, I call someone, tell them what I'm doing, with what, no BS, no inflation or deflation. And let them grind me a cam and I install it the way I'm told to lol.
Thank you, allow me to turn my head around and read through this stuff again. It will probably make more sense I go reread this stuff without that idea stuck in my mind:thumbsup:
---------- Post added at 01:12 PM ---------- Previous post was at 01:11 PM ----------
Have you tried to get SmallEngineCams on the phone? LOL
I'll call Dyno Cams. Sorry Joe.
Jrgunn5150
Rudderless
Lol, is there no one custom grinding cams for these thing's?
Timmy from DynoCams says more overlap = more top end?
Dyno cams will let you pick the center lines on any of there grinds.
Small Engine Cams lets you pick from a choice of lifts, duration, and LSAs
Jrgunn5150
Rudderless
If duration stays the same, yes.
The relation of valve diameter to cylinder bore matter's greatly, compression ratio matter's, many factor's matter.
What does dynocam's recommend?
This is one of those times when I take a wrong turn on purpose cause I was going to show up to the party too early and too sober.
I'll come back to the Cam choice after some more metaphorical pre-gaming! lol
Besides I need to pick a head first!
There are these options...
14cc
18cc
22cc
22cc Hemi
I know the 22cc Hemi has 27mm intake and 25mm exhaust.
I know the 14cc and 18cc has smaller (25mm intake?????, 24mm exhaust?????)
I'm not sure what the non-hemi 22cc has. If it is the gx200 head, I think it has the small valves too?????????
Milling the non-hemi heads helps un-shroud the valves to improve flow from what I've read.
What you you guys want to work with. I'm thinking similar compression ratio near 11:1.
---------- Post added at 02:04 PM ---------- Previous post was at 01:49 PM ----------
Quickly (meaning very polite, but ready to take an opportunity to say Good bye) he recommended the 275 which is 0.276" Lift, around 239/240 duration and said he can turn the lobes where ever I wanted.
We didn't get into that too much. The F-275 has 260 duration for 8000+ vs the regular 275 at 7000RPM.
With 1.3 Ratio rocker, I'll have a lift of 0.356.
I guess I also have to consider what is more important between compression and valve lift.
If max performance comes at 0.350" valve lift and max compression comes at 0.030" Piston to Head Clearance, it seems like there may be a trade off/compromise.
Then consider deck height and quench and now I'm glad I'm in no hurry to do this!:cornut:
---------- Post added at 02:22 PM ---------- Previous post was at 02:04 PM ----------
Apparently the best head is the RTC-8 head off the 69730 Predator.
These are the droids I am looking for!
Flyinhillbilly
The great cornholio
North West Arkansas
I disagree. More overlap means higher peak power, but less overlap aids in cylinder filling at low rpm meaning less peak power, but more area under the curve if you're talking about the same duration and lift.
---------- Post added at 04:38 PM ---------- Previous post was at 04:17 PM ----------
Here ya go
http://www.lunatipower.com/Tech/Cams/CamSpecTerms.aspx
Jrgunn5150
Rudderless
Widen LSA, broadens powerband, and reduces maximum torque :cheers2:
Which is what I was getting at, I just said overlap initially instead of Lobe Separation. Too many terms got thrown around lol.
