A New First!!!
kibble
I banned myself
I can use the grinder to make cuts? Keep in mind I will be making about 50 cuts.
If you use a cutting disc, a regular grinding wheel would probably not be a good choice.
Ahhhh, no. Im not making 50 cuts with a hack saw. My arm would fall off. LOL
Nuh uh! You'd just get really buff in a short amount of time! Besides, with a good blade and cutting fluid, making cuts with a hacksaw isn't all that bad. I've done it before.
Sdannenberg3
Semi-Effective Member
Chandler, AZ
Well ya, I just meant do you think it would be worth buying a metal cutting blade in my wood cutting saw since im doing so many cuts. But I heard that its not the best idea to do that. But then some people say its 100% OK. soooo
kibble
I banned myself
I've done it and it works fine for me. I have a Dewalt though and I don't know if that makes a difference. When I need to cut wood, I switch out the blade.
Who needs the lube!
You'll last longer with lube, well, the blade will last longer with lube. :arf:
newrider3
Colorado
Sawzalls are the epic FAIL!
/fixed
Nothing like having your piece vibrate at a high enough frequency to move the table it's clamped to, and not cut at the same time. Even using the guide, and a brand new blade.
Grinder w/ cut off wheel works AMAZING. If you don't cheap out, the more expensive blades last ages longer.
