8hp valve springs in 5hp?
Liberty_Jesus
Massachusetts
Will Briggs 8hp flathead valve springs fit in a Briggs 5hp Flathead? Are they even any stiffer? I've got my old 8hp engine sitting around and was wondering if I could steal the valve springs from it.
Brianator
Gettin' er done!
Barrie, Ontario, Canada
Someone else here may have a yes or no answer for you, I don't but I'll throw this out there... if you have a kitchen or triple beam scale you can find out an estimate of how many lbs the springs are rated by adding weight until they're compressed. Also check compressed height on both and compare, compressed height measurements need to be accurate to within thousandths of an inch or you'll end up with coil bind which could lead to catastrophic failure... if everything seems to be checking out you could assemble the motor with them and then measure between the coils with a feeler gauge to be sure theres some clearance. Also you dont want to put springs in that are much heavier and none that are weaker either.
Brianator
Gettin' er done!
Give others a chance to chime in they may already know these things but neverless a feeler gauge is cheap ($5), easily obtained and is something you should have if you're considering working on engines. A vernier caliper (dial gauge included for ease of use) could fairly accurately measure height and shouldn't be too expensive, I think I scored my Empire brand for $30, its plastic but seems to do okay for what it is and comes in handy for me quite often.
JTSpeedDemon
2019 Build Off Winner!
Texas
I think the 8 HP springs might be a little bigger, which will in effect give slightly stiffer springs if installed in a 5 HP, but honestly I doubt they'll even fit the retainers.
On their own, they are probably about the same stiffness, given that an 8 HP will redline around 5200 RPM, the same as a 5 HP.
What internal upgrades have you made to the 5 HP? It might not be a good idea to put stiffer valve springs in, depending on what internal upgrades you've done. Also, 18 lb valve springs made for a 5 HP flathead really aren't that expensive!
