8hp briggs carb issues
B.M.800
TheBeal.
Central PA
OK soi need some help here. At a friends trying to get hit tiller running.
It starts then dies. Took the carb apart an poked out the passages. Its getting fuel and has good spark.
I tried adjusting the screws but Im not sure I've got it right.
Here's the numbers, model type and code.
1954312 014901 81081111
Thanks
B.M.800
TheBeal.
Central PA
^^I dont think thats it, Im pretty sure the gaskets are sealed...
Does this carb have a sort of diafram thing in it? There was a piece that got ripped a little bit when it was taken apart and I wonder if that could be the problem?
I it a special material to make it? Or can I use some gaskets material to make one?
Something else, there is a bolt going into the bottom of the carb, hold part of the throttle assembly to the carb. Should it go the whole way through e carb wall? I kind of wonder if it wasnt done right cause it stripped out easy, what size is it?
I would like to run a tap in the hole an put a new bolt in. It seemed like there was some trheads it was gripping, but even with loctite I dont trust it.
Thanks.
Also, the carb on this 8hp is I believe the same as whats on my 11 and 6hp, Ill get a picture of one of those later so you know what I am talking about.
B.M.800
TheBeal.
Central PA
Nope we done evolved to something higher!:D Its like this one
This kind of carb have a special name?
B.M.800
TheBeal.
Central PA
Thanks ... funny thing is, he just sent me a text saying its running great. I dont know what happened. :huh:
Ohwell...
Now, I need to know what size tap we need to use and put a new bolt in there...
