Mr.Mediocre
Yeah, when I got the suspension and all, I thought man I should just throw this into a Mini K Truck. It’s about the same size and weight of a UTV. But cost stopped me!I'm not an EV expert, but I do have some electronics knowledge and did research building a homemade EV for commuting. It didn't pan out dollar wise (a ****box gas commuter is still cheaper to operate than buying batteries), so I didn't build it.
Yeah this is all a matched set, from different UTVs but same model. I guess I never thought about the idea that they could be running 82v (72.6 nominal) to the controller but the controller is just sending 48v out to the motor. That could explain why they claim to get 70 miles of run time in the lowest setting with the bigger 13kW battery pack or whatever comes with it. I’ll be interested to get it all plugged up and see what readings I get.Is that controller what comes on these UTV things you're getting parts from? Is it the same motor from the same UTV? It seems like a very nice sophisticated controller...
I thought I saw Lithium-Phosphate somewhere but I just double checked and they are all Lithium-ion. And yeah they advertise max voltage not nominal, so 60V is 56V the 82V is 73V weirdly enough. And The 80V batteries don’t say their nominal voltage. When I set out into this project, the idea was to have removable batteries that could be easily swapped and also charge back up in 90 minutes. I have no idea how long the slightly bigger 3kW pack would take with the heavy duty wall charger either.The 82V rating must be due to different batter chemistry?
Motors seem to be lying around more than anything so I can definitely keep an eye out. As for the suspension, I think there are two units with coil overs on them still. Cutting the full sections probably wont happen now that they are in there at super sketchy angles, mine was in the bottom with nothing around it when I went in. I’ll keep an eye out so some goodies.So, everything in those pictures looks like awesome stuff to me. It would be fun to get my hands on one of those motors, and any of the suspension parts.
@MTScott Thank you for the brain dump, I’ve been fascinated in all of this tech for awhile now and have struggled to find a one stop source for good breakdowns and explanations so I feel like I’m just piecing it together.
I think I ready somewhere that the phase wires to the motor should be equal length, Anyone know how important that is? I had some scrap EV Cable I used to make these but as soon as I finished I thought… Shoot I think those are supposed to be the same length.
