I'd say go for it. With decent gearing, you should have no problems with a clutch. CVT's really shine in offroad/hilly conditions, and when gearing is less than ideal. I can see no real reason why you cannot make due just fine with a clutch here.
EDIT- Those clutches are nothing particularly noteworthy as compared to a high-performance race clutch. That said, there is no reason you cannot use it. I use off-the-shelf clutches all the time. Good to go.
And FWIW- I LIKE those L-head Tecumseh engines. One slight word of warning- SOME Tec carbs are a bit sensitive to trash in the gas, or improper storage. Install a fuel filter, and always run the carb dry by shutting the fuel off and idling till it dies when putting it away for more than a couple days. Follow my advice and you'll never have an issue with the carb.
