70's Johnson Kart grave save
Chuckeroo
Springdale, AR USA
Hey guys.
I've started refurbishing my mid 70's Johnson Kart. It was in pretty bad shape. Lots of rust. I am not a body man, paint pro, or mechanic. But, I thought if I was going to put a motor and tires on it, I should try to make it look decent.
So, I've started the strip it to the metal and prime it phase. All sanding was done with either an small orbital sander or by hand.
If anyone is interested, I will post additional pics.
Thanks
A person who never made a mistake never tried anything new.
Albert Einstein
Great start but, as J_Walker suggested in your other thread, etch primer would've been a good idea &, before that, a dose of metal conditioner may have been a good idea. Oh well, you know for next time now :D
This looks like an old concession kart (with the outriggers & whatnot) so don't expect it to break any land speed records...
What are your plans engine/transmission wise?
Chuckeroo
Springdale, AR USA
It had a 4.5hp Honda circa 1975 on it previously with a tc. I'm uber heavy at about 300 pounds and it seemed to be hitting around 15 in the poop condition it was in.
I would very much like anyone's input on engine and clutch.
First, I have my eye on the HF Predator 212cc for $99. Would it work with the old tc from the 4.5 hp Honda? Would everything line up?
Top end is not as important to me as good low end. This thing will just be run in a school parking lot or two.
Is it to too much to hope for a "zippy" low end kart at my weight? Would I have to jury rig a 16hp motor to get any satisfaction? If so would the clutch be $1 million bagillion bucks?
Sorry, got a lot of crazy questions. But, luckily, you guys seem to be the ones to answer them :) .
Thanks in advance for anyone's help.
Chuck
Chuckeroo
Springdale, AR USA
Here is the original setup.
Thanks
loud1
Fat Guy On a Little Bike
St. Louis, MO
My brother-in-law picked up one of those several years ago and put a 2 stroke Suzuki 250cc engine on it. We had to stretch the rear end and put a live axle on it new breaks, blah blah blah. It ended up doing 60 or so before the piston burned.
If the crank on the old engine was 3/4" you'll be good to use the tc on the predator. As far as speed, can't help ya there but I'll let you know how my mini bike fares as soon as i finish it, I'm 260.
***edit***
Oh wow, that looks like a gear reduction, as long as Honda hasn't changed the pto mounting pattern the tc may work. Personally i would get a predator for $99 and a tc off of ebay for around $120 and keep the Honda engine as a conversation piece.
If that is the engine that you had previously, then you did not have a TC. That silver thing is a reduction box which has a wet clutch inside. The reduction is generally 2:1.
Chuckeroo
Springdale, AR USA
Doh! Shows how little I know about this stuff. Ok, so, wet clutch. I wonder how much HP that thing is good for?
Also, any ideas on maximum engine size possible in the space available on this kart?
Would I see an appreciable difference with the HF Predator 212cc vs the old Honda engine?
Thanks much.
Chuck
Thanks much.
Chuck
The Predator would outperform the Honda, cos it is a 6.5HP engine as compared to a 4.5HP. The reduction box should fit. Measure the shaft diameter of the Honda and the predator. If they are the same they should all fit.
loud1
St. Louis, MO
Ah, a wet clutch. I've only seen engines with a reduction box, I have never had any experience with them.
Chuckeroo
Springdale, AR USA
Crazy cool. Thanks for the info.
Here's a random question. Has anyone else noticed that Harbor Freight lists the 212cc Predator in their ads as a 6.5hp unit, but when you look at the actual item, in the details it says 7hp?
Thanks
Yes, we've discussed that previously; the reason is that the 7hp claim can't be verified so, it's advertised as a 6.5hp which is what honda claims for the original.
I'm with landuse re: reduction box; if you can get it to work on a predator, DO IT!
As for speed vs acceleration, that comes down to gearing; if you want speed use a small axle sprocket; if you want torque for acceleration use a larger axle sprocket. Actual numbers will depend on the reduction ratio; what's on the axle now?
Re: Honda vs Predator: A predator will be new whereas the honda is old &, probably, a bit tired so, the predator will be better, besides the fact that, as previously stated, a predator has more power from the get-go. Furthermore, the Honda has side valves where the predator has overhead valves which tend to be more efficient.
Chuckeroo
Springdale, AR USA
Hello again. The sprocket off the gear reduction box has 16 teeth. The sprocket on the drive wheel has 45 teeth. It has 11 x 3.60 slicks. I used the speed calc on here and got 42 mph as a theoretical top speed. Does that sound right?
Thanks
Thanks
That gives you a ratio of 5.625:1. This is slightly high, but with the 11 inch tyres you should be OK. You miscalculated the speed of the kart. Because you have a 2:1 reduction box, you will have to halve the speed, so your max will be 21mph. You can do the calculation on the speed calculator either using 8 as the clutch sprocket or 90 as the axle sprocket tooth count
Chuckeroo
Springdale, AR USA
Oh ok. I didnt think about the 2:1 reduction. That speed sure sounds a lot more like what I had experienced previously. So, if I do remove the governor and am able to reach 5000 rpm, I could theoretically achieve 30 mph. Sounds like a good start for me.
This forum is so awesome. In the last few days I have gone from thinking about power supplies, shaders, cpu voltage and multipliers to gear ratios, rpms and exploding flywheels! Awesome to put some new information in the old noggin.
Although, once I started adding up the cost for parts (header, flywheel, fuel pump, carb jet, tank etc.), I am starting to wonder if for the money, I should consider a larger engine.
On the other hand, the best part for me is always the tinkering and discovery. Which I would miss going with a bigger motor, leaving it stock, and not modding the 212cc.
Thanks much
mysteryboy28
Lansing, MI
the kart looks like it's got a LOT of extra metal on it. is the frame heavy? i'd dumb the frame down to the basics by cutting off all the extra tubing sticking off of it, using a grinder with cutting disks and sawzall. that'll help your performance a bit. plus i think it might help "modernize" your kart. lol.
Chuckeroo
Springdale, AR USA
The last thing I would do is "modernize" this kart. Johnson Karts has a rich history and I am facinated by the design. I think it's really cool the way it was over-engineered to be a concession kart. It is a beast. The bumper alone probably weighs 50lbs. Someone else told me to take it off and replace it with a 2x6. I said hells no!
I am will to sacrifice some performance in order to keep a piece of history intact. Maybe I'm overstating the significance of the kart, but this thing is almost as old as me. Maybe thats why it I really want to bring it back lol.
I do appreciate your input though and everyone else's as well.
Thanks
Chuckeroo
Springdale, AR USA
Hey guys.
I have the chance to buy the following for my kart.
Tecumseh Formula Horizontal Engine with Electric Start — 10 HP, 1in. x 2 7/8in. Shaft, Model# HM100-168416T
The guy that has it says it is practically new only started a couple of times. Apparently was going to do a project with it and things changed.
If it turns out that the engine is practically new, would it be a good engine for my kart? I am not familiar with Tecumseh.
I realize I would have to toss the reduction box and look at some of the pricier alternatives mentioned many times in this forum.
Anyhoo, he wants to sell it for $100. Good deal?
Thanks
Hey guys.
Thanks
It sounds like a deal, but like you said, you are going to have to get a comet 40 series that runs at about $300. If it were me, I would just keep what you got, but whats the fun in that!!!!
