I still do not agree with sellers claiming that the Tav 30 is good up to 13hp. The original Comet (yeah, the actual GOOD one) was only rated to something like 8hp.
Do yourself a favour. Spend the extra money, and get a Comet 40. Then you KNOW it will work well, and work reliably.
Thanks for your comments.I want to buy Chinese tav 30 because it is cheaper than Comet.Gearing of my bike 10t shaft sprocket and 32t wheel sprocket and 18" rim .32t sprocket is orginal motorcycle sprocket.
Comet 40-44 is fit for 8-18 hp,isn't it.Can i use comet 40-44 with my 7 hp diesel engine?
As far as I know you can use a Comet 40 on a 7HP, but it would be a bit of overkill.
