what about drilling out the clutch?
Depending on the hp:
If 8hp or below: if you wanted to use a 1" clutch on this they are about $120 + the cost of the adapter. You would be better off either:
1. Take your crank to a lathe, machine it to 3/4", cut a 3/16 x3/32" keyway.
This could be expensive if you have to take it to a machine shop.
2. Buy a new 3/4" crank
3. Buy a new motor and sell yours.
4. Search long and hard for a 7/8" clutch! (maxtorque will make you a custom one but they are probably around $200.
if your motor is over 8hp to 20hp:
1. Look for a 1" clutch or torque converter and adapter.
You'd get better response starting a new thread instead of hijacking someone else's thread.Does anyone know where I could find a replacement shaft for a kawasaki FA130d BS05?
Wait a min this is a vertical shaft engine, according to the model number you posted. what the heck kind of kart you trying to put this on ?
