7/8
berg
ive been searching the forum and all i could come across was using a 1" bore clutch with a bushing to adapt to my 7/8 shaft. is there a cheaper way to use my engine?
r_chez_08
Should be in the shop...
Cornwall, UK
Depending on the hp:
If 8hp or below: if you wanted to use a 1" clutch on this they are about $120 + the cost of the adapter. You would be better off either:
1. Take your crank to a lathe, machine it to 3/4", cut a 3/16 x3/32" keyway.
This could be expensive if you have to take it to a machine shop.
2. Buy a new 3/4" crank
3. Buy a new motor and sell yours.
4. Search long and hard for a 7/8" clutch! (maxtorque will make you a custom one but they are probably around $200.
if your motor is over 8hp to 20hp:
1. Look for a 1" clutch or torque converter and adapter.
the-cyborg
Spring, Texas
I seriously doubt it would be $200 I had Jim custom make me a couple if 5/8 to 9/16 step bore clutches with with needle bearings instead of bushings for my West Bend 820, and they were only $160 each, I wouldn't think it would take too much to for them to tool up fir a simple 7/8 (0.875) straight bore.
Contact Jim Donovan over at Max-Torque and get a quote, what can it hurt?
Here's his contact info.
James F. Donovan
Max-Torque, LTD.
2180 Corporate Lane
Naperville, IL 60563
Phone: (630) 369-9600
Fax: (630) 369-9686
Website:
www.maxtorque.com
Email: jim@maxtorque.com
Jcotz
...wasn't there
NY
I have been having this same problem and I have a 3/4 clutch. So I was thinking of trying to drill it out, but now that I see that bushing thing, I am wondering... is that just a thinner bushing? How would you pop out the other bushing? and the back of the clutch, which does not have the bushing, what would you do there?
Also... If you want there are 7/8 pully clutches, so you could replace your sprocket with a pully.
berg
where can i find a replacement crankshaft? when i look up the engine i have it doesnt say what the size of the replacement ones are so i dont know if it would be a solution to the problem
the-cyborg
Spring, Texas
Wait a min this is a vertical shaft engine, according to the model number you posted. what the heck kind of kart you trying to put this on ?
Jcotz
...wasn't there
NY
Does anyone know where I could find a replacement shaft for a kawasaki FA130d BS05?
That certainly explains the oddball shaft size. I certainly hope you have your drivetrain figured out- going through the great trouble of adapting your shaft or even changing it is a he//uva waste, if you can't use it to actually power something.
berg
ive adapted the engine to run vertically so now the clutch is the new problem
