6hp Tecumseh question(s)
Wilson_Engine_Shop
Supporter
Independence, Kansas
You are missing that linkage throttle plate. Shoot, I'll give you mine lol the only thing its missing is the linkage springs. There's two of them. I'll try and find the post I saw earlier about them.
http://www.diygokarts.com/vb/showthread.php?t=43262
I'd rather have the stock linkage over the way it was before I got my hands on it. Is that the exact plate I need? I'll PM you my address if you can send one to me. $10 isnt bad for the bracket anyway lol.
Brisketends
Corpus Christi, TX
Yea shoot me a PM. I don't need my stock linkage anymore. If you want it, you can have it. But you will need the spring set. I don't know if you saw the post I referred to earlier. One of the springs snapped so that's why I went with a choke style carb.
It's fairly easy to install if you decide to go that route. Go Power sports sells a VM22 kit with the linkage for about 100. You'll need an adapter though from GPS as well. Anyways yea man, which ever route you want to go, I'll help you out
https://www.gopowersports.com/22mm-mikuni-carburetor-performance-kit/
Wilson_Engine_Shop
Supporter
I just want to say thanks again to Brisketends for sending me his unused Tecumseh throttle plate with the hold down bolt I was missing! It fits perfect! I also fabbed up linkage from the Gov. arm to the carb. Now I get full throttle, idle and everything in between)! I now have a good spare 6hp motor (Govenor is deleted on the Tecumseh btw)
