6" driven vs 7" driven
MrC.
florida
Well guys
What's the difference in gear ratio between the two?
Im looking for more low end out of my tav 30 would this be noticeable?
MrC.
series 30 with 6" driven internal ratios: (low -> high)
2.7: 1 -> 0.9 : 1
series 30 with 7" driven internal ratios:
3.13 : 1 -> 1.12 :1
but you say TAV.. (which is the one with backplate...)
And you cannot mount a 7" driven onto the TAV backplate!
MrC.
florida
This is what I have
It has a metal backing plate and mount under the engine.
It says TAV30, but the driven is stamped with a 20, I know its old.
I want more low end gear, I was thinking about options other than a larger drive gear because of ground clearance.
I don't know if this is even the right belt or not, this is how I bought it.
I did just learn I am missing two washers/spacers on the driver. and when I floor it from a stand still it chirps the tires and shocks the drive line, when moving both sheaves seem to work correctly.
With this backing plate I don't see why a 7 inch driver would not fit. with the same bore of course.
Thanks
MrC.
KartFab
Dallas, TX
Its not a question fo if the driven unit will 'fit' its that the belt will not fit. See below
https://www.gokartsupply.com/tcbelts.htm
the 20 stamped on the driven unit has absolutely nothing to do with the series (20vs30) the 20 stamped on the driven unit cam indicates the angle that the cam peaks/valleys have.
The way to tell (besides clicking on the link above) is that the 20 series has symmetrical sheaves, and the 30 has a flatish looking one, and an angled one.
Finally, you cant do the 7" with that plate, but you can get more torque by simply purchasing an 8t type c 40/41/420p sprocket from any go kart supplier that sells azuza parts (gopowersports, ombwarehouse, bmikarts blah blah blah).
Also, your belt is worn out
Also, you need to clean at a bare minimum the drive unit. Im working on a video that explains every piece, but most of the time the problem is in that hub, you just need to wire brush out the hub so it can slide back and forth and spray some dry lube on it (dry graphite, dry moly) Driven units can have problems but they rarely do.
Hope that helps!
MrC.
florida
Thanks guys for the great feed back.
As we all know when we buy used karts, you always have to question what you have and what someone else has done to it.
As for the 7" driven just so I am clear the reason it will not work is because they do not make a 7" driven that meets the same profile as the driver 18 degrees/ 2.5 degrees. Correct?
Thanks,
MrC.
Thanks,
MrC.
NO INCORRECT!
they clearly make a series 30 driven in 7"..
it just doesn't fint on the TAV Kit (because there is no matching belt for that center to center distance!)
Frankly.. I think there is none for a reason ;)
Anyways.. getting a driven is not the problem, installing it on the backplate is.
PS if you miss low end... get a better gear ratio ... sorry, but it's indeed that easy ;)
