6.5horse rpm
dirtcheap
i have a 6.5horse champion motor (the one from costco) and i want to know what rpm i should see on it
I am using a 10 tooth clutch what size axle sprocket should i use for all around use of 15" tires
:sifone:
jr dragster T
Cold place
3600 RPM is max RPM. Dont worry the idle RPM will be lower than your clutch engagement. But I would say it idles areound 800-1000. For some reason my clone idles pretty high.
Magice
That's with a governer.. You should be able to crank 4.5k safely* from it without a governer.
Jerryburger
Admiral Annoy
The Nation's Catbox...er, AZ.
Depending on your kart weight and riding style, I'd gear it with a 45- 48 tooth rear sprocket. I'm running 16" wheels and a 45tooth on my trike, and it has plenty of "go" with a governed top speed of 38mph. Faster than it sounds.
