6.5 clone motor
mango494
Hi all ,new here ,from australia where we dont race these four banggers ! i have one motor with centrifugal clutch 10/48 gearing ,i have another motor the same but with a reduction box ,both have govenor removed ,my question is am i better off with the reduction box or without .also what gearing would i run on the reduction box motor to achieve better pull off the botttom ? than the 10/48 combination thanks ..
anderkart
Surprise Arizona USA
There's different reduction box ratios used like two to 1 or six to 1 for example.
To find out what yours is you'd need to count how many engine revolutions it took to get 1 full revolution at the reduction output shaft.
Then with this info and you posting how tall your back tires are we could suggest your gearing options for better pull off the bottom.
anderkart
Just simply swapping to your reduction box engine with the same tooth count drive-gear/rear-sprocket would give you much better pull off the bottom. Assuming your ungoverned engine would rev up to 5000 rpm under a load, you would end up with around a 19mph top speed. That should actually be some good gearing for what you want. I'd just try that same gearing combination and see how you like it with your 2 to 1 reduction.
Right now without your reduction box, your estimated top speed would be around 37mph @ 5000rpm. So with the 2 to 1 reduction you'd simply have twice the torque, but only half the top speed potential.
With no transmission, you'll always be compromising between top speed or increased torque. (or better "pull off the bottom" as you called it) You cant have both, so you just have to decide on a compromise that best suits your kart and driving style...
If you want to experiment with how other size rear sprockets would change your gearing with your reduction box, you can still just use this speed calculator: http://www.diygokarts.com/speed-calculator.html
But just simply double the rear axle sprocket tooth counts you enter, to simulate/compensate for using your reduction box.
Then If you were to buy and install the different rear sprocket, you'd simply get one that's 1/2 of the tooth count you used with the speed calculator.
Or, If you wanted to use the same 48 tooth rear sprocket, but experiment with a different tooth count driver gear on your gear reduction engine, you could simply enter a 96 tooth rear sprocket size, and calculate with how different driver gears on your engine would affect your top speed and torque.
It really all very simple once you think about it, but let us know if you dont understand any of this :thumbsup:
mango494
ok thankyou for your help on that have organised the gearing now ,my next issue now is that now that i have taken the govener out i would like to know about stronger valve springs ?? this motor is a 6.5 hp i read that u should run 18 lb springs once ungov,do the larger mtrs like your 8,9 & 11 hp motors have stronger springs that u can use ? i have been unable to source any here in australia as yet & a spring manufacturer here tried to make some for me but they turned out looking like truck valve springs !! how are they measured is the reading taken at some point of spring compression or should be 18 lb as soon as u compress ? what rating are the standard springs ? thankyou i hope i am not overloading u with questions !! thanks again .
anderkart
There's lots of different opinions on this matter, but I personally wouldnt install any performance valve springs in a clone engine unless I also installed a race type rod and flywheel. With the stock valve springs, your valves will start to float around 5500rpm giving you obvious warning your exceeding the reasonably safe rpm limits of your engine.
Below 5500rpm racing valve springs wont make any difference besides causing more valve train wear requiring more frequent lash adjustments. Do what you want, but If I was you I'd do lots of research before upgrading your valve springs.
You'll find good info in the Blog and tech video links near the top of the page found at this link:
http://www.arcracing.com/servlet/StoreFront
Some performance info along the right side of this page:
http://www.affordablegokarts.com/
Tons more info from kart racers and pro-engine builders available in these 3 links:
http://karting.4cycle.com/showthread.php?t=359833
http://karting.4cycle.com/forumdisplay.php?f=72 (most GX200 info also applies to 6.5hp clone engines)http://karting.4cycle.com/forumdisplay.php?f=120
mango494
ok thats easy then we will leave it ,thanks can you tell me a bit about header pipes please, like what length for short speedway style tracks where bottom end is essential would work best ? & help propell a 95 kg bloke around ! lol
anderkart
Take a look at the descriptions of all the different style race headers available in this link: http://www.robertsonstorquetubes.com/application.htm
If you want to design and build your own 2, 3 or 4-stage race header, you can download this program: http://www.kartingtechinfo.com/tech/pipemaster.htm
_________________________________________
So you weigh 95kg/209lbs and race on a speedway type racekart track against much lighter drivers?
Unless your just a much better driver and/or have a much better handling kart than everyone else, you'll need a more powerful-higher revving engine (with lower gearing) than those lighter guys to win.
You sound kinda like me. I weigh 107kg/235lb and race karts on a very small speedway type track here in the states. You'll find lots of info/race-videos about how I finally managed to win against lighter drivers here in my 2 threads:
http://www.diygokarts.com/vb/showthread.php?t=3664
http://www.diygokarts.com/vb/showthread.php?t=6364
But basically, I had to get a larger more powerful race engine, get a better kart designed for oval racing, and do a better job setting up the tires and adjustments on my kart. I also had to learn to drive very smoothly so I didn't loose speed and momentum around those small tight corners.
Anyone can drive fast on straightaways, the races are won or lost in the corners.
I'm not rich, I didn't just out-spend the other racers at my track. I did LOTS of research first, then hunted around for bargains and bought most all my stuff used for a low price. Then I had to spend lots of time out in the garage making every single part (and adjustment) of my kart work the very best it possibly could.
Winning is all in the little details, you've gotta have everything just right to win. But If a lighter weight kart driver has done as good of a job at everything as you, you'll still loose every time just because your heavier.
Some racekart tracks have have different (minimum weigh) classes to make it easier for the heavy drivers to compete, my track doesn't.
