5HP Briggs wont start
bullet15963
hey guys, I have an old 5hp Briggs and stratton that suddenly wont start, this engine did work fine when I got it, took it apart anyways... The gas tank has a nice layer of rust on the inside, I managed to sandblast most of it away. The carb was quite clean already, so I cleaned it. I replaced the spark plug with a new e3 plug. After its all back together, i just cant get it to start. When i pull it, full choke, all that happens is some white smoke and sometimes sparks come out the air intake (probably not good.) Some times white smoke will come out between the head and block, so the only thing i can think of is to get a new header gasket because I'm not getting any compression. Any thoughts?
Did you disassemble the entire engine? Perhaps when you put it back together you did not time the cam properly? Or perhaps you damaged the head gasket when you took it off, but tried to reuse it? Maybe a stuck valve? Damaged rings? There are a few possibilities for the lack of compression, I think you need to take it apart and do it again.
bullet15963
I didnt take the entire thing apart, the head was taken off to clean the top of the valves and piston, no further. ( Im pretty sure the gasket is ok, but thats the first thing im going to check)
Blazkowiez
Kart Aficionado
Houston, Texas
Whenever you pull an older engine like that apart and you can afford it replacing the gasket is a good idea. Unless I know the gasket is not really necessary I tend to never re-use a gasket.
I know this sounds silly but I also don't trust E3 plugs, Champion CJ8 or J8C will be just fine for a 5hp Briggs.
cbr600rr1
Martinsburg, WV
Are you sure that the valves are ok? It sounds like one of the valves have something stuck in them & keeping them from closing all the way. Also it could be you have a bad sparkplug & its keeping it from firing
Justin
I don't know bout flat heads but on ohv's if you don't got Ur valves adjusted right it won't work.
