Wilson_Engine_Shop
Supporter
So i'm getting ready to clean up this old 5hp Briggs and get it running again after sitting out for a couple years. I'll be getting a new carb and inspecting everything inside. My main question is, what is this assembly under the tank? Is it governor related? Can i remove the governor and this thing and still have a good running engine? Its the original engine off my Carter bros. kart but its just going to be a spare for it.
The tank has quite a bit of rust in it but its still solid. I plan on pouring Evaporust or something equivalent in it to remove the rust and reuse the tank since new or used ones cost around $100. Any advise on this rebuild? My older brother originally "rebuilt" the motor in his Small Gas Engine class several years ago.
I also have no idea where the throttle cable is supposed to be hooked up either
