I doubt it heres its details
Engine-Name UP168
Engine-Type Engine-type 4-stroke, 1 cylinder, air cooled, OHV, petrol engine
Displacement (cc) 196
Spark F6TC
Max.Power 4,80 kW / 6,50 hp at 3600 U/min
Start: Recoil
Oil-Type SAE 10W/30 winter / summer
Fuel consumption (g / PS / h) 290 g
Fuel Super-Unleaded Petrol
Tank (Super Unleaded Petrol in l) 3,60
Oil content (in l) 0,60
Cooling Air-cooled engine
Gross Weight 18 kg
Dimensions in cm 41,7 x 36,8 x 38,5
Engine Bore (in mm) 68 x 54
Ignition system transistorised
Engine-Stop-System vs Ground
Air-Filtration System Dual Silent (Semi-Dry)
Compression 8,6 : 1
Volume (dBA / 7m in distance) 78
the shaft is 20mm and the clutch i got is for a 19.05mm shaft
