The 5.5" Live Axle Hub is a must-have component for any off-road vehicle, including go-karts and dune buggies. Made with high-quality and durable materials, this hub is designed to provide optimal performance and longevity. It's also compatible with a wide range of tire sizes, making it a...
Cindipdx, that's a good find. I've tried to locate metric stuff for folks and mostly failed, I ain't British. Just now put that GPS page in my favorites column for the future.
Those hubs were just what I needed. Had to enlarge the holes a tiny bit. I have the whole assembly mocked up in plywood. Need to tweak my CAD drawings a bit then get my parts cut by the waterjet.
last picture was an early mock-up in the frame
Is that the Miata diff ? I did the same thing, but I made a sheet metal CAN to contain the gears, then put 2 zirk fittings in the can and filled it with grease.
No I’ve known about it for years. The problem is where I live out in the sticks there ain’t any Myattos around for me to snag one. So I forgot about them. I hope you got the axles, hub bearings and control arms too. It would make your life a whole lot easier. Bonus points if you got the brake rotors and calipers also!
I didn't get any of the other stuff. This will just be a simple rigid axle. No room under the 'glass shell for anything else. Just a bar hopper not a freeway flyer.
