4hp Kohler k141
Badot
Don't try using electrolysis with just a transformer unless you use/the transformer has a rectifier as well... Transformers output AC current.
That, AND there could be an unseen fracture in the casting- the balance issue could possibly be dealt with, but an unseen flaw could spell disaster. Okay you spell disaster "D-I-S-A-S-T-E-R". But you know what I mean. I'd start looking for a new flywheel.
j.concepcion54321
Rebuilding KTM, Need Kart
East Providence RI
well to take the flywheel off i banged it a couple of times with a hammer and then used a a crowbar to pry it offf :) well yeah i was able to get it off and just left the carb how it was and tried to start it up. i also took the head off and clean off some of the grease that built upp in there. well yeah the engne didnt strt when i tried it. what other problems might i have? is it because the choke doesnt work and the carbs not in too great condition?? i didnt put a lot of gas through it either. how do i check for spark?
Bluethunder3320
to check for spark you need to turn over te flywheel. a puller is the right way to remove a flywheel, but i dont have a puller and the way i do it is loosen the nut half off the shaft, pick up the engine by the flywheel only, a few inches off the ground, and have a buddy tap the nut with a hammer. with small 2 strokes you can hold the flywheel and do it with one hand tho.
There's a couple ways to check spark. Easiest is with a spark tester. If you don't have one, remove the spark plug, and reconnect the lead to it. Now- there's a couple ways to handle this, here is the best way I have found- Take a length of copper wire, and strip 1" of insulation off one end, and 2-3" off the other. Loosen a bolt on the engine, wrap the short-stripped end of the wire around the bolt and retighten. Now, wrap the long end several times around the threaded portion of the spark plug. In low light, yank the pull-start a few times. Spark will be obvious if everything is okay. Make sure plug is in good condition and correctly gapped before testing. If unsure of spec, 0.030" is a good ballpark gap. You can skip the whole wire thing and just hold the plug tightly against a clean bare metal part of the engine, but it is difficult to do while pulling the starter. The wire trick makes that much easier...
j.concepcion54321
East Providence RI
ok ill have to check that out tomorrow. what can i do about the carb because thats my main concern right now? i left it sitting in some wd40 all day and the choke still doesnt move, everything else in the carb looks good, but that choke is really killing me.
j.concepcion54321
East Providence RI
can i just let the whole carb sit in some sort of solution?? like a mix of water and something else thatll work kinda like wd 40, because thats not too cheap and neither is gas soo. maybe water and like baking soda??? idk give me ideas
j.concepcion54321
East Providence RI
how abot giving it a good spray with some wd 40 and then leaving in some really hot water so that it breaks it down while cleaning it at the same time. ill try it out tomorrow and let you guys know how it goes.
j.concepcion54321
East Providence RI
okay so when i took the sparkplug off to test it, and went to put it back on it wouldnt go in. and then i notices some of the threads from the head are gettting off as i try to put the spark plug in. WTH!!! how bad of a situation am i in?
