j.concepcion54321
Rebuilding KTM, Need Kart
ok will do that first thing tomorrow. ill try to get as much done as possible tomorrow and post some pics
to check for spark you need to turn over te flywheel. .
There's a couple ways to check spark. Easiest is with a spark tester. If you don't have one, remove the spark plug, and reconnect the lead to it. Now- there's a couple ways to handle this, here is the best way I have found- Take a length of copper wire, and strip 1" of insulation off one end, and 2-3" off the other. Loosen a bolt on the engine, wrap the short-stripped end of the wire around the bolt and retighten. Now, wrap the long end several times around the threaded portion of the spark plug. In low light, yank the pull-start a few times. Spark will be obvious if everything is okay. Make sure plug is in good condition and correctly gapped before testing. If unsure of spec, 0.030" is a good ballpark gap. You can skip the whole wire thing and just hold the plug tightly against a clean bare metal part of the engine, but it is difficult to do while pulling the starter. The wire trick makes that much easier...
