LoneRanger
- Messages
- 2
- Reaction score
- 0
I just picked up a HF 9000 watt generator with the 13hp/420cc predator motor..
After some research I noticed a couple people mentioning the 420cc motor run on the lean side and have a tendency to not last very long with the lean condition.. Is there any truth to this and should a jet kit picked up ???Also is there anything I should look or keep aware of that may cause a problem ??? Oh I almost forgot the unit came with a cracked spark which was a Torch F7TC but the manual recommends the Torch F6TC plug.. So what is the right spark plug and does it matter if it comes with resistor too ???
Thank you
Thank you
