Hey folks, have a yard kart with a 420 and 40 series tq, red springs and heavy weights in the driver, 10/50 gears. Live axle with 13” slicks.
Engine is stock as a 2x4 and runs great, just hits the governor.
Since I’m opening up the case to remove the governor, would I need to replace the connecting rod and flywheel on the other side? Never found a straight answer unless putting 50lb valve springs so valve float stops. Then yes for sure.
If not, I’d just put a header, jet, and air cleaner on and be done.
If the flywheel and rod need swapped regardless, valve springs, cam, and a carburetor. If I go this route, I’d like something that pulls hard from driver engagement(2600rpm allegedly) to around 6000, is that a realistic option?
Thanks in advance.
Thanks in advance.
