40 series driver mounting
Brett066
Bunker Hill, Missouri
Can a 40 series driver be mounted inboard?? Or I guess a driven modified to run with the spring side outboard??? Otherwise, it looks like a new motor mount is in order because my alignment is waaaayyyy off. Thanks in advance guys!:thumbsup:
Brett066
Yes, thank you!!! I kept researching after i posted. I am just goin to have to order a spring..... I was just hoping maybe the driver would be flippable to save $. Oh well.
driven[jackshaft] MUST be mounted inboard (unless you change the spring to the yellow reverse wound) then it can be mounted outboard as well
(I say it must[should] float,
Grant disagrees with me...
I have not even touched a series 40 in my life, he runs several [all inboard afaik])
the driver[engine] however must run outboard and it must not float.
