So the reason I'm disassembling it is because it's engaging too early and killing my engine. It kills the engine because when it engages it's just idling. So I assume the springs need replaced and maybe more. If it's too much I may just buy a new one.
It had bad rust and I cleaned it up the best I could because I couldn't get it apart. It has pitting now that I can clean further when I get the darn thing apart.
So I'm not sure but it looks like the large welded nut is threaded inside but I can't get it to turn off or anything. I don't know how to hold it down without damaging it. So I started soaking it in pb tonight in hope it may loosen up. The only thing I can do it put a large pair of channel pliers on it and try to hold it and turn it off. I don't know what else to do any help is appreciated thanks.
