3HP Briggs not running right
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
:roflol: Our exchange rate is only approx 7 rand to the dollar, so not so bad. It does make things a bit expensive though.
At least your not in Iceland. Ive been walking around with a 500 kronur bill in my wallet since last summer thats worth about $3.50:roflol:
Did you try tuning it?
There is only a idle screw, and I tried from nearly closed to nearly totally open. Nothing. Is that what you mean by tuning?
have you tried this after you installed your new gaskets?
Thanks, I totally forgot about that. I will try and see what it does.
Check carb flange mounting for warp.
Warp is caused by over tightening.
No amount of gasketing can make up for that.
If there is no obvious warp, how would you tell if it is warped. I assume this is the mounting from the carb to the tank?
