3HP Briggs not running right
I thought I would post this problem in the engine section and not in my minibike build.
On saterday I decided to work on the engine that I am going to be using for my minibike. It hasn't been running well, and all I thought it really needed was a carb clean. So I got the engine out, bolted it to the workbench and got going. I used THIS link to give me a hand in the dissasembling and cleaning. THIS link is also helpfull with identifying Briggs carb problems.
The first couple of pics are of the carb before I removed the thing. I took Bigheads advice and boiled the carb in lemon juice, cos I didn't have any carb cleaner handy. After that I cleaned out all the jets and holes with a copper thread from a wire brush. Some of the holes were quite dirty. After putting it all back together, filling the tank etc, I had to put some fuel down the plug hole to get it going.
I still had a problem in that i could get it running, but not idle properly. It would keep on dying. If I incresed the idle, it would then idle high, but at least I could rev the engine. SO AT VERY HIGH IDLE I COULD REV (SORT OF), WHILE AT IDLE IT JUST BOGGS DOWN. I decided to clean it again yesterday with some carb cleaner I bought, and it is still pretty much the same.
I have a video of it running (or not running well) here
http://s1103.photobucket.com/albums/...ent=briggs.mp4
I am using a brand new one though. The engine wasn't working so well, so I bought one and put it in. It still didn't run well so I did the carb clean that I detailed above. It definately runs better, but not great as you can hear.
Should I take a pic of the diaphram so that you can see what it looks like? It is new though
karl
North east Ohio
If its new then it should be good. Did you take it apart when you boiled it? Take the jet out and boil it. Hows the spark plug? Points cleaned? Whats the stuff on the spark plug wire?
I took everything apart when I did the boiling. I am still using an old plug, so maybe I will get that changed out. I do have a new one that I haven't tried yet. I haven't cleaned the points. I thought I would try other options to get it running before I tried to mess around with taking the flywheel off. I am pretty new at small engine repair
I am assuming that the stuff on the spark wire you are talking about is that plug looking thing. I actually have no clue. I assume that the plug wire had to be extended for some reason, and they used that plug to do it??? I have a pretty strong spark, so it isn't doing anything funny there.
Did you replace the gasket between the engine and carb?
No I didn't. The person who had the engine before me had used stuff called gasket maker, which is sort of like a black paste. I thought that it still looked good. Should I clean it all off and get a new one?
If I spray a bit of carb cleaner, or starter spray round where the gasket goes, should the engine rev a bit if it is sucking air? If so, I should try that to see how bad the problem is.
Bluethunder3320
it would rev higher or run smoother if you spray carb cleaner around the gasket.
i would just make a gasket out of a thin piece of cardboard or a cereal box.
I was just wondering. If I make a gasket out of a cereal box, I will have a smooth side and a rough side, because the outside of the box is usually smooth where the writing is. Does this matter at all that the one side is smooth?
sexyvicta
option B: go to lawnmower shop and buy correct gasket for 1 dollar (5 million rand?).
option c: buy some gasket paper.
Bluethunder3320
i would highly suggest you get the correct gasket,
but,
i have made plenty of gaskets out of cereal boxes and none have failed me yet. i found out this trick too, you use a hammer to cut the sides of it off the surface, its hard to explain but i remember seeing a video. if i come across it, i will post it.
EDIT: sometimes i peel off the smooth side, if its small enough, but havent had problems just keeping it.
:roflol: Our exchange rate is only approx 7 rand to the dollar, so not so bad. It does make things a bit expensive though.
but,
Thanks Blue. I know what you mean about cutting it with a hammer. I will scrape all the gasket maker crud off and try the cereal box thing this weekend. If that doesn't work, I will go and spend 5 million rand and buy a gasket. :D
So I bought some gasket paper over the weekend and made some gaskets for myself. I scraped all the black gasket sealent/maker stuff off, and put the new gaskets on. I got the engine to run a little bit better than what it was before the new gaskets, but it is still not good. I still can't get it to idle low, and it seems to "hunt" while it is running. Trying to rev the engine also causes it to bog down and die most of the time.
Should I double up on the gasket paper to make it thicker? I smeared a tiny bit of vaseline on the gaskets to create a better seal. I heard from a small engine repair guy that this works well. I bought a 0.4mm thickness gasket paper. I could have gotten 0.8mm, but thought that might be overkill. Was I wrong?
I am not too sure what to try now. Any ideas.
Here is another vid of it running after changing the gaskets.
26062011029.mp4 - 17.52MB
