karl
Figured I would share to help save some motors from the scrapyard.
The engine is a 357cc 11-12hp "clone" MTD conglomerate engine that suffered a LOL. (lack of lubrication)
The engine has a 83 x 66 bore and stroke, so you cannot use any honda , or other clone parts. Just about everything is slightly different. Check the angle of the carburetor.
So I would need to buy a crank from MTD, that is not worth it.
Anyway I tried this old school trick and it worked great!
I wiped Muriatic acid, with a regular acid brush on the journal. I kept going for about 10min until all the aluminum transfer sizzled away. Some light scotchbrite and Its ready for service!
Wash very well, super corrosive.
Small engines dont use babbitt bearings, so the soft aluminum rod does not harm the crank much.
I wish I took a before pic, I thought It was scrap, so I did not bother.
I found a rod on ebay for $25, the total cost to revive this engine. Not too bad , this is my first big block clone.
If you try this at home please read the bottle, take all safety precautions, and use common sense.
