357cc Blown Rod Revival
karl
North east Ohio
Figured I would share to help save some motors from the scrapyard.
The engine is a 357cc 11-12hp "clone" MTD conglomerate engine that suffered a LOL. (lack of lubrication)
The engine has a 83 x 66 bore and stroke, so you cannot use any honda , or other clone parts. Just about everything is slightly different. Check the angle of the carburetor.
So I would need to buy a crank from MTD, that is not worth it.
Anyway I tried this old school trick and it worked great!
I wiped Muriatic acid, with a regular acid brush on the journal. I kept going for about 10min until all the aluminum transfer sizzled away. Some light scotchbrite and Its ready for service!
Wash very well, super corrosive.
Small engines dont use babbitt bearings, so the soft aluminum rod does not harm the crank much.
I wish I took a before pic, I thought It was scrap, so I did not bother.
I found a rod on ebay for $25, the total cost to revive this engine. Not too bad , this is my first big block clone.
If you try this at home please read the bottle, take all safety precautions, and use common sense.
And I thought it was only good for cooking up some meth?
Jk, nobody ever shared recipes while in jail. Lol
karl
North east Ohio
Ill buff out, right?
It should make a full recovery.
karl
North east Ohio
Took a whole slice to get that dang bearing out!
The governor will removed along with the balance shaft.
karl
North east Ohio
Well I noticed a very small crack in the skirt of the piston, and the other side was chipped, so I haft to order a piston :censored:
Anyway I shall call it the 357 Magnum!
While I have it apart , should I turn the crank to 3/4 and run a 3D manual clutch, or use a sleeve and run a 40 series?
This will probably be used on a lighter go kart or minibike.
Also I want to use a different carb, any recommendations?
karl
North east Ohio
Got the new piston in.
Just waiting on a head gasket.
Made a straight pipe, should run soon.
